Go Back   Power Hungry Performance Forum > Power Hungry Performance Product Information > Rev-X Oil Additive > FAQS - Rev-X Oil Additive
Old Thu, August 19th, 2010, 04:24 PM
cj45lc cj45lc is offline
Yes I have always thought quieter is better so maybe there is something to this. I'll be interested to see what the dyno says when Bill checks it out in his 7.3 Hey thanks for the stickers
Old Thu, August 19th, 2010, 04:32 PM
Almost forgot, thank you for the stickers! Hope you have a good trip Cody, & thanks for all your help!!
Old Thu, November 11th, 2010, 12:38 PM
majek5's Avatar
majek5 majek5 is offline
Nothin' Stock
If the truck appears to have no issues, will the rev-x be beneficial? I have read about the stiction issues with the 6.0. So will it help a healthy truck?
'06 6.0 F350 CCLB KR.
stock...
Old Thu, November 11th, 2010, 05:58 PM
Many of the current Rev-X users have noticed an improvement even if they weren't experiencing any obvious stiction problems. I would say the benefits are probably not as impressive as those experienced on a problem truck, but there should still be some benefit.
I'm going to be doing a before/after test on our truck as son as I get the oil changed. It's a 7.3L, so again the gains might not be what others experience, but I'm curious if there will be anything noticeable.
Stay tuned for results.
Power Hungry Performance - The ORIGINAL in Ford performance tuning... Since 1996!
Old Fri, November 12th, 2010, 06:58 AM
Bill's going to dyno the Expy and the 7.3L before using it and after so that we'll be able to share some numbers. I've heard nothing but good things about it!
Are you going to use in a gas vehicle?
Thought it was for diesels?
Old Fri, November 12th, 2010, 07:02 AM
I'm real interested in what you find on your 7.3 Bill. The only thing I have to go by is the romping I was getting before. I guess there are a multitude of things that would contribute to the romps & I'm just guessing the injectors are probably tired 184k. Oil always changed @ 5k intervals since I've bought it with 45k on it. I will say that when I added the Rev-X I did a little different in that I ran the oil about 2500 miles then added the Rev-X, my thinking was that I had pretty good idea of how mine ran on fresh oil. The engine got quieter in the time that I would guess it took to go through the HPOP. I haven't had a romp since & I really believe it fires quicker on starts.
Old Fri, November 12th, 2010, 10:19 AM
Rev-X is simply an oil additive. There no reason to think that there wouldn't be any benefit on gasoline engines as well as diesels. That's why we're going to give the Expy a shot. I've got to get the 75K maint done next week and will dyno before and after the Rev-X treatment.
CJ,
That's good to hear. The guy at Rev-X indicated that he'd seen positive results on the 7.3L as well, although maybe not as significant as the 6.0L. I guess we'll find out soon.
Old Fri, November 12th, 2010, 09:35 PM
Jeremy's Avatar
Jeremy Jeremy is offline
Spark Plug Inhibited
I didn't notice much on my 7.3 with it, but was alittle quieter. The 6.0L was noticable though, much smoother. I need to order more, I used it in my 06, my 00 7.3 and the 05 Ex. The Ex hasnt really responded to as well as the 06 did but its still better. Now that its getting colder at night 25F, I'll see if it helps with the colder starts.
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Sun, November 28th, 2010, 06:28 PM
Jeremy's Avatar
Cold Start report...
Spend the Thanksgiving holiday at the family cabin in Montana. So I had a chance to see how the rev-x performed for cold starts on the 05 Ex. The Ex has a non-heat inductive flash in it, its a stock 03 program as I requested from Bill. Before on a mildly cold day 35-40F, the Ex would struggle, pop off and die when started at these temps. I believe I have at least one weak injector, that will be replaced here in a while. I waited to replace it so I could see how the rev-x helps a truck with weak injectors...like most of us probably have. Well I decided to use a day that hit 0F. We had few days that hovered around -15F but I do not like starting them un-aided(no block heater) at those temps especially with 15w40 in her. IMHO its not good for the engine. So at 0F she fired right up, and had the usual 6.0 cold start clatter. It started and ran without dying...so I'm very pleased with the results. The product seems to do as the claim.
my $.02
19 F-350 6.7 Auto
16 F-350 6.7 Auto
Old Sat, April 9th, 2011, 04:02 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
That guy...
So did you ever do the Dyno test w/ the Rev-X?
I am tempted to run it, if for no other reason the crappy ULSD fuel...should help keep the lubrication properties of the oil, I'm running AMSOIL 10-40CJ-4 at 10K intervals.
Just curious!
All Contents Copyright 2008-2020, Power Hungry Performance
