Old Thu, May 28th, 2009, 07:25 PM
Question Chip Tuning Questions
According to my tracking number I wil be getting my new FU2 chip in the mail tomorrow. I plan on putting it in this weekend.
When I ordered Corey stated that there may be some need to fine tune it some of the tunes. My question is what tunes will most likely need to be adjusted and what perameters on the truck EGT, Boost, Shift RPM, ect will I need to pay attention to and notify Bill of to make sure everything is set right?
My Tunes are
High Idle
Stock
80HP Daily Driver
65HP Fuel Sipper
120 HP Race
Moderate Tow
I understand that the high idle and the stock settting will probably not need attention and the 120 HP race will probably need the most if any.
Joe
Old Fri, May 29th, 2009, 03:10 AM
The things to address are usually low-speed drivability issues, smoke control, and EGTs (especially for towing). Best to generally start from bottom and work your way up.
Old Fri, May 29th, 2009, 08:20 AM
I'm just going to throw this out there......
The shift points on your fuel sipper program will likely need about 2 minutes worth of "fixing".
Old Mon, June 1st, 2009, 11:57 AM
Cody,
I am not sure what you mean by adjusting. I won't be able to do that will I?
Joe
Old Mon, June 1st, 2009, 03:24 PM
Sorry, I just had to re-familiarize myself with the FU2.....
No, you can't change it yourself....oops.
