Old Sun, June 7th, 2009, 01:41 PM
tim @ p.i.s. tim @ p.i.s. is offline
tim @ p.i.s. is on a distinguished road
Originally Posted by dlmcbm View Post
well i ran my truck on the dyno Saturday and......
I guess i am pleased with the results but not were i wanted to be.
first my truck is a 2001 F-350 7.3L with a DIY air filter and 4" turbo back exhaust. I have a Phoenix chip and ran it in stock, 100HP and 140HP settings.
first was stock setting @ 227.01HP and 449.9torque
second was the 100HP setting @ 290.68HP and 585.93 Torque
and last was the 140HP setting @ 307.02HP and 607.74 Torque
I really wanted to see 350Hp and 700 torque so i guess i will have to go to the hard $$$$$ parts.
any suggestions on what to do first injectors, turbo then oil pump???? this is still my daily driver so i dont want to go to extremes nor do i really have the $$$$$ to do much at all right now.
Most BONE stock sd's are in the 200 range, your intake and exahust are helping you there a bit. The 100 is spot on and the 140 is going to give the same results as the 120 without any extra oil(HPO). So everything looks pretty good. You should be proud for a fairly stock truck with little investment. A fuel systems upgrade and hpo upgrade will net little hp increase, but make for a much happier smother running truck. And also set the stage for furture upgrades. I have installed many sets of stg 2 single shot injectors in PMR engines. The key is to have good tunes
And 4K can get you way more than 50hp, way more.
