Old Tue, June 9th, 2009, 12:10 AM
Originally Posted by DarrenWS6 View Post
I am seeing it during breaking, so I suppose it is normal? Hopefully. I monitor everything like a hawk, even look at my dipstick every week lol. Ok i'll keep that in mind, The most work my battery usually does is play music with the windows down while i'm working outside or at a campfire, nothing real major. I still have the stock battery too, it is indeed a trooper. And thanks for clarifying the idle adjusting for me, thats exactly what I wanted to know. And obviously, returning it to 0 will be normal idle? Jack, thanks yet again for the information, much appreciated. Learning more and more every day.
Yes, Darren, setting the idle in the Custom Options menu back to zero will put it at the stock tune setting that Bill created for you.
There may be an easier way though to get totally back to the "virgin" custom tune - just program it in and completely bypass the Custom Options step. Or, if you want to have a "Previous Settings" file that is mostly "virgin", open the Custom Options menu but DO NOT "Load Previous Settings". If I've got this right, you are now in the process of creating a NEW "Previous Settings" file, but most of the settings are what Bill wrote for you. There are two exceptions though - Tire Size (TS) and Gear Ratio (GR). One or both of those values will now likely be wrong and you'll have to manually set them. Check both and adjust as necessary. Then, scroll to "Done" and let it program. The new Previous Settings file will hold Bill's values and your TS and GR.
As I said though, I don't know if the RPM drop during braking is normal or not, since I don't recall ever looking at it. I don't think I get that big a drop, but I cannot be sure.
And, I'd give Bill's settings a try before trying to "customize" them. After all, it's what you paid him for. Also, if you don't like something in them, it's probably best to discuss that with Bill, so he can fix the root cause, which is different than you putting a "band aid" on it with "Custom Options".
