Old Thu, June 18th, 2009, 08:25 AM
Originally Posted by soutthpaw View Post
YES you can modify all the standard files Bill sends you with the Minotaur package.
This is correct!
they are not encrypted or anything. This is different from DP tuner for example. you cannot modify his tunes or add your own tunes to empty spaces on his F5 or F6 chips for example.
Well.......
If you want to tune additional vehicles you will need to purchase the MDF files for the specific hex code. if it happens to be a PCM in the same family you don't need additional MDF's
This is also correct. By family, DJ means the "DPC" code. DPC-203, DPC-402, DPC-411, etc.
Cody can tell ya all about that I think he has a whole collection of them he has never used
Yeah. In addition, there are a lot of definition files (mdf) that will work with other families......but not all of the correct values will match up. Some binary will, most won't.
as there is only a few OEM PCM files that are really good like the PMT1 EBM1 etc... you may have to disable the PATS or reprogram it with something like AutoEngunity software..
That's mostly true. Yes, PMT1 is my absolute favorite as I tow a lot and I'm not in what most would call a high altitude (3900 ft.). However, listening to a lot of other people (especially in altitudes like yours DJ), the PMT1 is not the best for towing there. I don't know this for a fact, but certain other codes do not have such....uh..."abrasive" converter lockup strategy.
PATS....what a joke. GM has had a similar system for many years (Pass-Key. 3 versions of it) and every one is a piece of garbage.
