Thread: help
Old Sat, June 27th, 2009, 05:09 PM
Originally Posted by PoisonXA View Post
i just wanna know what you guys have done while you wait. like for instance where to put the shift points and firmness and etc etc i just wanna know what you guys have done.
What WE have done will not be right for you.
But, IF you use level 3 and IF you fill with 93 octane, you should be able to add +1 degree of timing. You may want to set your 1-2, 2-3 WOT shift points at or near 5000, and the 3-4 WOT shift point around 4500. Set the Max RPM to 5400.
Some people like to increase the shift firmness, I didn't. Those that do seem to use around +10 for 1-2 and 2-3 and around +6 for 3-4.
Stresses on the 3-4 shift are the highest, so don't be aggressive on that one.
I reduced my part throttle up and downshift speeds and TC lock/unlock points to save gas. You might want to do the same or increase yours to improve on part throttle power.
And, as Lars said, read through the "Custom Options Q & A" too. You'll find it here: http://dygytalworld.ehost-services13...ead.php?t=1101
