Old Mon, June 29th, 2009, 09:08 PM
How are you measuring the temps?
Using an ir gun or the gryphon. Set the gryphon on CHT pid it should be anywhere from 202-208 if still at stock or canned tunes. If you have custom tunes it will be 2-4 degrees higher. So set the second one at 210?
Take her for a short test run to confirm. Others have gone through the expense and mounted leds to see when theirs turn on.
This maybe simpler.
This is courtesy of f150online. They are using the ECT on the edge. Here's the link:
http://www.f150online.com/forums/v8-...ml#post3055325
