Thread: Engine temps.
Old Wed, July 15th, 2009, 11:55 PM
408F150 408F150 is offline
408F150 is on a distinguished road
I'm using a Reese 800tw/10,000gw Anti-Sway WD hitch (the kind that use break pads inside the WD bar brackets for the anti sway), which seems to work very well. I specifically chose my gearing to put me around 2100 rpm @ 55 mph with the OD locked out. I've geared and modified my truck as much as possible to keep me from having to buy a 250/350 since once you hit 8000#, 150's really start to get tapped out. They can tow it, but it's not fun. Gearing and cooling seem to be the two most substantial ways to make towing easier once you start hitting the 150's limits. My manual says I have a 9100# tow limit, but I'd never, ever pull that much weight in stock form. Next on my list is brakes in case my trailer, God forbid, decides to lock up or lose it's breaks one day.
