Old Mon, July 27th, 2009, 10:03 PM
kd4crs's Avatar
kd4crs kd4crs is offline
Not a Whopper
kd4crs is on a distinguished road
I just got around to purchasing the alternate rigid 3 inch tubing that fordmt08 on f150onloine.com used for his intake modification and it looks like it will work well installed a couple of different ways. The tubing required is made by Spectre Peformance. It is part number 8741 for the black color (8742 is Red, 8746 is Blue, 8748 is Silver) and it is called: 3" Flexible Air Duct. It is priced ~$20 and should be available at O'Reilly Auto Parts and Autozone stores. I installed it completely collapsed using one of the two connectors that come with the kit to go into the fender inlet and using the downspout connector to connect to the stock flexible section. It fits perfectly and does not require any hose clamps. I will be testing it out with my Gryphon Custom 87 performance and Custom 87 towing tunes this week. This variation completely eliminates any possibility of the downspout connector collapsing or getting sucked inside out.
