You won't have to disconnect your Gryphon to check. Just make sure you have registered your Gryphon using Help->Registration.
Then, you can check to see if your tunes are ready by just clicking on Updates->Current Update Status.
Once you see there are updates ready for you, set your truck back to stock, plug your Gryphon into the PC with Pegasus running and then hit Updates->Targeted Functions. Follow the directions. DO NOT leave your PC unattended until the tunes are loaded, and don't let anyone else get their grubby paws on your PC!
When the tunes have finished loading, simply disconnect your Gryphon from the PC, turn your truck's ignition to ON (don't start the engine) and plug the Gryphon back in. Then, program your new custom tune into the PCM!
