Old Wed, August 12th, 2009, 08:46 AM
967.3L4x4's Avatar
967.3L4x4 967.3L4x4 is offline
Minotaur Newb
967.3L4x4 is on a distinguished road
Okay, let me see if I can help a bit. The FU wouldn't work for you because of your injectors. So you'd be looking at the FU2 (custom tuned 6-position chip and burner) and/or Minotaur. The FU2 package is $675. You wouldn't need everything that comes in the Minotaur Package if you purchased the FU2 first, but you can purchase the Minotaur Software, MDF, and base calibrations for your PCM code for an additional $450. So when all was said and done, you'd have a 6-position chip, a chip burner, 6 custom files, the Minotaur Software, the MDF for your truck, and access to all of the base calibrations that we have for your truck for $1125. Whew!
Ok so if I buy the Minotaur now then I save the $450, right? The Minotaur package comes with everything the FU2 does plus the Minotaur Software?? For the same price? Basicly all that I get from buying the FU2 first is the 6 custom files? But if I have the Minotaur then I can buy a few custom files for how much?
Thanks for the help.
96 7.3L E4OD, Ext. Cab 22x,xxx miles
Intake, Exhaust, 6.0L IC,
4 Wheel Disc Brakes. Dana 60, Electric Fuel,
SD HPOP, 6" Miter cuts, 3" plenums
Rosewood Stage IIs, Built tranny.
Minotaur with some tunes from Bill
Planning: Traction bars, HPOP, Nitrous??
