Old Sun, August 23rd, 2009, 12:40 AM
Originally Posted by 1999RedXLT View Post
Started the truck after work yesterday and the Gryphon was DEAD. No LCD illumination, nothing. Truck started and ran fine. Turned the truck off and back on a couple of times - no change. Turned off ignition, unplugged and plugged Gryphon cable a couple of times. Turned ignition back on - nothing. Unplugged Gryphon with engine running, plugged it back in - did a cold start, i.e. showed me Hex code, etc. then went to menu. Operating normally since. I'm in central Florida and it was pretty hot yesterday, but I put my hand on the pod and it didn't seem excessively warm. Does the Gryphon have a thermal cutout in it?
Feel better Corey!
It's more so the LCD screen that has a heat issue. It usually goes black at temps over 120-125. Now if it's 95 out in the sun it could be +30 degrees warmer than 95. Some goodways to prevent the heat exposure are sun shades windsheild shades. Park in shade. Or remove gryphon from pod.
