Old Sat, August 29th, 2009, 04:53 PM
Originally Posted by kord View Post
I'm looking into buying the Minotaur package and possibly an extra chip for my dads truck and from what I've read it sounds like I'd have to buy other files to tune his truck because we have different PCM codes. His code is XLE-4 and mine is NVK-4 is there any way I could get away with using just one set of files and still tuning both trucks? Thanks for the help
NVK4 "officially" uses a VNAA8 definition while the XLE4 uses the VHAE9 definition. Trying to use either one of these files with the "wrong" definition will not work. Some things "line up" in the parameters, maps, and functions but most do not and it would be impossible to tune.
The right thing to do would be to buy both definitions and get the base files for each truck. However, with the expense of purchasing both, it might not be financially feasible to do. Besides unless he absolutely HAS to live with his XLE4, it's not worth trying to tune it to do anything worthwhile.
What I would do in your case would be to upgrade his truck to a DPC-422 PCM (his is a DPC-402 now) and both of you could run any tuning you wanted to; be it both NVK4, PMT1, or whatever you wish since they'd be in the same family.
