Old Wed, September 9th, 2009, 01:54 PM
aaron ford aaron ford is offline
aaron ford is on a distinguished road
Okay, module installed. Wow. Little more work than I envisioned. I have yet to drive it, but I did test start it. I thought I would share some ideas before I forgot.
Whisper makes the morning white smoke horrendous. Gonna hafta test this one after it warms up.
The PCM comes out after removing the two bolts and the sealing flange on the firewall. E-brake has to come out to allow access to push the PCM out of the clips that hold it in. It comes out through the firewall.
I never did figure out how to remove the board from the case. I cleaned it with the scotchbrite (Thanks!), acetone and Q-tips.
I did not find a gold colored ground tab.
I found that to route the switch wire past the e-brake assembly, the top stud had to be spaced with a 3/8 inch nut behind the assembly to prevent squishing the wire.
The inner fender liner has to be one of the seven layers of hell....
Had I remembered, I would have taken pics, but I did not. Perhaps someone would be willing to take photos of their install to help those that are about to jump into this project. Paticularly how the chip interfaces with the PCM board.
Now let's go drive it!!
Aaron
