Thread: Seat Covers
Old Wed, January 14th, 2009, 07:26 PM
jfuller5 jfuller5 is offline
Location: Upstate New York , Cambridge . lake george area
jfuller5 will become famous soon enough
Hey Dixie- I put rear seat cover on my 08 screw a PIA , not real hard left seat in. Bottom is staight forward but seat back gets a little tight. Get some stiff cardboard and cut a strip approx 3 inches wide and abot 36 inches long, now cut 2 slits in one end of the strip approximatly 2 inches long. Put the entire cover on seat back as best as possible and then place one of the straps that needs to go behind the seat back and tuck it into the 2 slits cut into the cardboard. use the 36 inch piece as a tool to push the starps down behind the seat and now you can get your hand in between the seat bottom and back to feel this cardboard and pull strap out , you can now attach it where needed. the cardboard is stiff and thin and allows you to push the strap down the back where you cant see or get your hands, otherwise it is like trying to push a rope. This works and takes about a1/2 hour to install back cover. Hope this helps. Jim
