Old Mon, September 28th, 2009, 11:29 PM
Originally Posted by fordkindaguy View Post
My best guess is that you probably have off road tires and they are not balanced correctly. With larger tires this is common.
Good answer!
Also this Is the pinion angle set at the proper pitch with the use of shims or tapered block? If this isn't done you will start to go through ujoints also.
I have seen tapered blocks put in backwards an upside down along with shim wedges forgotten.
Just some ideas!
