Old Sun, October 11th, 2009, 12:01 PM
Rustler Rustler is offline
mad cow member
Rustler is on a distinguished road
Mine on canned level 2 acts the same as you state, empty.
I saw 92 ~ 98 % once when I pulled out on the 2 lane 70 mph speed limit country road and smushed the go pedal to da floor loaded with 2 round bales + 500 lbs of alfalfa cubes on the trailer and 500 lbs of corn in the bed.
IIRC 1st & 2nd were around 80 %, 3rd TC locked was 94 ~ 99%, OD was around 75% max, any more pressure on the go pedal caused a downshift.
I did have my trans shift firmness set higher wot shift points higher and some other things adjusted through the custom options menu.
07 F150 screw, 5.4, auto, 4x4 esof, lariat.
Gryphon with 87 performance custom tune.
275/65/20 dura tracs, 2" AS - 3" block, true duals with h pipe to flow pro dido, ugly arsed tips pointed in a funky fashion.
