Old Tue, October 20th, 2009, 08:40 PM
goracer's Avatar
goracer goracer is offline
goracer is on a distinguished road
JBA shorties, 4 oem stock converters. This is my second set. When the 1st ones broke I could see the blue flames shoot out at startup in between the broken section of the passenger header.
Stock exhaust merges with a "Y" section to a single pipe. I replaced the "Y" with an "X" and continued with dual pipes. Allthough the Magnaflow muffler has an internal "X" the section I replaced gives it rigity since the brackets are only on one side as they are intended to hold a single pipe.
Oh, do you know how to clear the engine codes?
When I pulled out my Edge and I had an old check engine light. I disconnected the battery and stepped on the brake pedal. When I started it it the check light was still there and the truck would not go in to gear, nor would the gas pedal work (it physically moved but no rise in rpm). I get really worried as it' not possible to push (and the Edge is in route to PHP). I restart about a dozen times in park, neutral, let it warm up and finally it works but I still have a check engine light. Grrr!
