Thread: just ordered...
Old Mon, November 2nd, 2009, 06:40 PM
Originally Posted by antzfreshwhip View Post
yes, i have tried it that way..i mean its way to tight...i can get the insert it, but it dont sit nice, and then i tried to slip the gryphon in and i dont see anyhow that it will fit...lol
Edge seems to have had some quality control issues with these new pods. Another member had one that would not fit his dash at all (it was distorted). If you could measure the opening, which of the dimensions is too small? Is it the width or the height? (I know it's not really a rectangle, but what are the "rectangular" width and height)? If they don't correspond to what they should be, I'm sure Corey will send you a replacement. I wouldn't try trimming the pod unless Corey tells you to try that.
In the meantime, you CAN program your truck, and if you can somehow hold the Gryphon in the pod temporarily, you can drive it and enjoy the display. When I got mine, Corey forgot to send the rubber insert (Sorry Corey, I know I'm telling tales now, but I don't know any other way to tell this story). I kind of "wedged" the Gryphon in place in the pod with some pieces of plastic door trim I had laying around. It worked fine, but the effect was much better when the insert arrived.
Edit: I just read your last post - glad it's fitting. I think it's supposed to fit VERY tightly! (And, the insert will not look right unless the pod is in it.) When all's said and done, it should look like the picture on the front of the Gryphon Manual, which happens to be MY Gryphon in its pod!
