Old Mon, November 2nd, 2009, 07:57 PM
JWBFX4 JWBFX4 is offline
Originally Posted by XPerties View Post
I know this is an semi-old thread but prior to the Edge being upgraded to the Gryphon whenever I programmed hot or cold I never got any of the "check gauges" on my display. My Gryphon just came UPS today so I had to run around for a bit and when I was at the local 7-11 I programed to my custom tune and I got the "check gauges" displayed which did go away after the programming was done.
I've never seen this and it did cause some panic attack for a second.
Well I figured I would chime in since I started this thread a while back....
Although since your truck is an 05 and the battery MIGHT be weak, IMHO I don't think thats the problem in this case.
Ever since I have started this thread and changed levels my truck has always said check gauges. Now mines an 06 with the original battery and I thought it could be a bad battery so I swapped in the battery out of my friends 08 and went to program and bamm the same thing happened. I think Sburn's post got the problem just right.
Because the oil pressure and the coolant temp gauge are the two not working (in my case) and I assume since it will not give a reading to the gauges during programming the truck thinks one of them are broke.
