Originally Posted by Matt_g
I bought a locked Gryphon programmer for my 5.4 a couple weeks ago  . Is there a way i can unlock it myself or will I have to send it to Bill to have him do it?
Thanks
I think you DO want to contact Bill. You may not need to send him the unit, but he'll probably need the Serial Number to be able to help you. properly.
Could you possibly get the guy you bought it from to return the tune on his truck to stock? This is what should have happened!
Or, is it possible the unit simply does not understand your truck's hex code when you attempt to program YOUR PCM? If that's the case, it possibly still has custom tunes installed, which won't work on your truck. Those can be replaced with a calibration update through Pegasus.
