Old Wed, November 11th, 2009, 09:57 AM
I owned a 2nd gen. Cummins. It was a 94 with a 5 speed. It was a pulling machine as long as you kept the RPM below about 1800. The early 24V trucks had a similar RPM threshold. The problem associated with the mechanical ones (as well as the first 24V ones up to '02) was that it was hard for a truck to have "multiple personalities" and be easily changeable from a tame commuter into a pulling monster. Besides, those trucks literally fell apart around the engine. The automatic transmissions were made of fine crystal, and the interior smelled like urine.
The advent of the common rail brought with it a much better Dodge truck (that actually came with bushings on each end of the track bar), better transmission strength, and a more versatile RPM range in which to run. They're quieter too....if you're into that sort of thing. Listening to an early 24V all day long gets really old. I don't have a problem with noisy diesels but those were over the top.
