Old Fri, November 13th, 2009, 03:35 PM
AZFX4 - I moved your thread to the Gryphon forum because you don't really have a "problem" that needs fixing.
I think, from your question, you may have a misunderstanding about the Tire Size (TS) and Gear Ratio (GR) settings. If you have custom tunes and you told Bill what your TS and GR are, or if both the TS and GR are OEM, with canned or custom tunes, you DO NOT have to do anything - the correct values will be loaded into your PCM.
If that is not the case, you will need to set them by using the Custom Options menu. Please read this Q&A before you even start doing that though: http://dygytalworld.ehost-services13...=9248#post9248
When you select a tune level to load into the PCM, you are given the chance to "Create A Custom Program". If you choose "Yes", you will be taken to the "Custom Options" menu. Here is where you can set your TS and GR, among other things. You cannot simply check that the values are right! The TS especially, will probably ALWAYS be wrong! For the reason this is so, read the Q&A I refer you to above.
There is no way for you to simply "display" your TS and GR in the Gryphon.
Hope this helps.
