Originally Posted by cleatus12r
What year is your truck and what was your PCM code before you installed the Phoenix?
Shift timing can be a bear because everyone's tastes are different, but since it's only one shift accompanied by the TCC apply, it won't be a big deal to fix. Depending on what Bill has done it can be fixed pretty easily in a few different ways.
With the 99.5-03 trucks my new best friend has become "Delay converter lock after 2-3".
Cleatus12r, thanks for the quick reply. My truck is a 2003 F350 dually with 410 gears, the PCM is coded VDH5 but is was reflashed by a different tuner, I don't know what the original code was but is has always worked ok. I still have the original PCM that came with truck packed away. Hope this will help.
Don
