Old Sun, November 15th, 2009, 09:01 PM
So you have power than attempt to start and loose all power? Classic voltage drop, trace out all you big cables and see where they go and check them for looseness. Should be able to find your problem right away. You could also have a buddy hold the key in the "start" position and systematically wiggle you cables untill you restore power. BE CAREFULL keep all of your limbs and loose clothing away from moving parts!
Good Luck
