Thread: More ?'s
Old Thu, November 26th, 2009, 12:57 AM
Default More ?'s
1. Can this program be used to disable trouble code's?
I have a few things that have gotten removed over the years and they trip codes. Not a big deal because they wont turn on the CEL, but they can be quite annoying when watching datastream while driving. About every 30 sec. or so the scanner will pop up a message saying DTC triggered than begin to record pid's. This can be aggravating when I am focused on a certain thing. The codes that it is triggering is for the Air Intake Heater, Wastegate Solenoid, and EBPV. There might be more but cannot remember.
2. Can you change the programming to alter when the wastegate solenoid is activated?
I have twin turbo's and have only one wastegate on the primary charger, and the gate is being controlled with a manual controller. I plan to add a second gate to the secondary charger and thought it would be pretty cool if it could be controlled with the factory solenoid.
3. Can the programming be changed so I dont have to run a boost fooler, and how would this effect everything else?
I think thats all for now but I know there will be more.
