Yes I am using the Genisis
and it is very annoying how the data stream locks. Also the damn thing will just completely stop and then return to the start up menu........but only on my truck. Never experienced this on any other rig. I have been wanting to upgrade to something a little newer with a built in labscope like the Verus, but it is way to much for my wallet.
As for the map sensor the only reason I would want to enable it to see higher boost is so I can use the factory wastegate setup. If it will read 25-27 PSI that will be perfect, thats about where my drive pressure on the secondary starts to get a little high and just gets worse from there. Looks like I have some experimenting to do, but I need to focus on one thing at a time.
