There's also this method:
In the Gryphon's main menu select Diagnostics->Tech Support->Version Info. Ignore the warning you'll see. If your tunes are custom, you should see "0.x.xxxx" in the calibration version where the last 4 x's are usually the same as the serial number. If the tunes are "canned", they'll look like "1.x.xxxx" (the version number will start with a one ("1").
So if your calibration version begins with zero ("0"), you've got custom tunes.
