Old Thu, December 17th, 2009, 08:04 AM
Ryan,
Please fill in your information in the User Control Panel so we can better answer your questions. We've got a LOT of Ryans in our customer list.
1) We've updated the software so that it now explains that "Connecting to Bridge" is normal and at this point the update is complete. I know this has caused a lot of confusion for folks.
2) I'll have to investigate this issue. Could you please indicate what settings you're originally using so that I can try to duplicate the problem. I can also pull the files from your unit to see what's getting corrupted and that may help as well. Get back with me on this.
3) If you have a 97-03 truck, there are a limited number of PIDs to monitor. The problem is not the programmer as we could relatively easily change the firmware. The problem is that the cable itself handles the PID requests and then forwards the data upstream to the programmer. Unfortunately, there is no TFT PID (or other useful PIDs) in the cable so the programmer isn't able to access that particular data. The website is pretty clear on what PIDs are available for each programmer (http://www.phptune.com/_Ford_F-Serie...e_Vehicle.html) and if there was any misunderstanding in that regard then I certainly do apologize.
