Old Fri, December 18th, 2009, 08:35 PM
CageFighter_Dan's Avatar
CageFighter_Dan CageFighter_Dan is offline
Almost not a Newbie
CageFighter_Dan will become famous soon enough
With a tuner you should be able turn off/ or bypass the pats system, once that is done the fuel situation should be fine, as well check the 30 amp mega fuse in the engine bay on the drivers side, by the cruise control module, I forget the number of its position but it controls power to the pcm as well
When the going gets tough slap it in 4wheel high and plow through the junk!
