Old Fri, December 25th, 2009, 11:54 AM
dpizz450 dpizz450 is offline
dpizz450 is on a distinguished road
I'm going to try to clarify something here. DO NOT use Fusion! Download and install Pegasus if you want to update the firmware in your Gryphon. The Gryphon will not work with Fusion.
If you got an Edge manual with the unit, it's mostly correct, but you should actually be using the Gryphon manual which you can download from PHP's website.
If you have the F1 error, try this: Leave the ignition key in the ON position. Unplug the Gryphon for about a minute, then plug it back in with the key still ON. Then, try to program your vehicle.
Now, it's possible that by using Fusion you MAY have corrupted the firmware in the Gryphon. I don't know at this point. If the Gryphon is unplugged, try this: Turn your ignition key to ON, then plug the Gryphon in. If you see your vehicle's HEX code, you're probably good to go and you can try programming it again. If you do not see the HEX code, you're going to have to get help from Bill.
Thanks man, I highly appreciate it. Yes i got that part about the software. I deleted fusion and d/l pegasus. I updated it through that. About to go hook it up on the truck now. I will let yall know later today. Thanks again and MErry christmas and happy new years!
