Old Sat, December 26th, 2009, 12:36 PM
Sorry for the confusion, DJ. The maps are THE SAME MAP. It just so happens that I was confused since I have definitons that have it listed as either one and that the new ones that are listed as "offset" do not contain correct information.
The MAIN advantage to using the SOI Delay map is the fact that the SOI can be changed based on engine oil temperature. A side benefit (or detriment) is that it is an indirect way of getting a greater SOI advance at higher RPM.
