Old Sat, January 2nd, 2010, 11:03 AM
GeauxTigers GeauxTigers is offline
GeauxTigers is on a distinguished road
Everything seems "ok" with the battery as far as amps go...don't know what else to check.
So, I unhooked the Gryphon from the truck. Plugged it back in (with the truck in accessory position) and programmed my settings back into the truck . It prompted me to turn the key off, then back on, but not starting it....like normal.
I let the truck run for a bit. It sounded pretty bad (knocking). Then turned the truck off.....waited a couple, and started it back to see if it would hold my settings, and it had reset again....
Just some more FYI. Thanks guys !
