The firmware hasn't changed in forever and all the PIDs should be in there. Here's the list...
Engine RPM
Vehicle Speed
Engine Coolant Temp
Engine Oil Temp
Trans Fluid Temp
Cyl Head Temp
Intake Air Temp
Line Press Desired
Actual Fuel Rail Pres
Output Shaft Speed
Turbine Shaft Speed
Mass Air Flow
Mass Air Flow Volt
Variable Cam
Spark Adv
Torque Control
Engine Load
APP Sensor
BatteryVolt
Inst MPG
Avg MPG
Commanded Gear
Check and make sure that your firmware is version 3.02.0639. If it's not, you'll need to update the firmware.
Let me know.
Bring back  Windows™ XP and 7.
 Windows™ Vista and  Windows™ 8 is a pain in my a$$!
