Old Wed, January 13th, 2010, 08:11 PM
andrew's Avatar
andrew andrew is offline
andrew is on a distinguished road
Hey travis are you going post or pre turbo? Post is ok but better to be pre if you do it pre turbo look up from under your truck as if you were changing the oil. The exhaust manifold is just above and to the right or out side of the truck try to drill in the center of the manifold. Tap the hole and insert the probe and hook it up.
