Thread: Econ Tune
Old Thu, January 14th, 2010, 02:38 PM
GeauxTigers GeauxTigers is offline
GeauxTigers is on a distinguished road
Jack- I went ahead and did what you guys suggested , but I'm having a problem with the truck going in to overdrive in 3rd gear. So, when I'm cruising in 2nd or 3rd gear (usually just 3rd gear) I go from roughly 1000 rpms to 1800+ rpms...and back and forth, until I either speed up to 50 mph + or slow down drastically.
Here's what I did in my Gryphon settings so you can address the problem directly:
Shifting
1-2 -2
2-3 -3
3-4 -5
4-3 -5
3-2 -3
2-1 -2
Std. Conv. ---> I put all the allowances to the maximum negative number for each of the gears (8; 2 for each gear).
Let me know which gear(s) I should change and by how much.
My guess: Change the gear converter for gears 1-3 back to 0 and just change gear 4. OR change 1-2 gears back to 0 and just change gears 3 & 4 to the maximum alllowance ... Thanks guys !
