Old Fri, January 15th, 2010, 01:19 PM
Originally Posted by ticopowell View Post
Of course and I love your quote!
I think the quote's one of the best I've seen in a long time too! Colin Powell seemed a VERY intelligent General.
Back to your problem: Try using the custom options menu again, but this time, DO NOT adjust the WOT fuel (I'm assuming you may have tried resetting that before). In the past, that particular adjustment has caused the symptoms you describe. Leaving it alone seems to make everything fine.
Why this should be, I don't know. But, you probably do not need to change the WOT fuel anyway. Bill has it set so you get enough in any high demand situation. Let us know if this fixes the problem, please.
Now, if it's not that setting, it's probably one of the others. You can try adjusting each of them, one at a time, until you find the one that causes the problem. Then, tell us which one it is.
