Old Sat, January 16th, 2010, 11:37 PM
Wouldn't the added fluid help maintain slightly lower temperatures? I don't know if this would be a significant effect or not, but if it's a 15% increase in volume, it should help some.
And, I sure wouldn't put anything but Mercon V in it.
Just thinking out loud.
The extra capacity pan allows more fluid but still is limited to the transmission body.
A larger external cooler would have a more dramatic effect on cooling the fluid then a slight chance from the extra capacity.
However the OP doesn't state what extra capacity pan he is going to use?
If the pan is made out of aluminum and finned then yes the cooling will be better than slight but still not as good as a larger cooler.
