Old Sun, January 17th, 2010, 12:28 PM
DarrenWS6's Avatar
If I'm reading what you're saying correctly, you're "golden"!
Since you DID NOT choose the Gryphon Update Manager, you didn't do anything at all to the Gryphon. It will work the same as before when you take it back out and plug it in to your truck (with the key on). Even if you HAD mucked up the Gryphon software, the truck will run fine without it, it's just acting as a monitor now.
Now, if you really DO want to change the splash screen, after you have it connected to the truck, set the truck back to stock and THEN bring the Gryphon back to your PC for that task.
Looks like you "dodged a bullet"!
Sweet deal, thanks! Had me a bit worried because I need my truck everyday, and it completely skipped my mind to put the truck back to stock before removing it.
