Old Wed, January 20th, 2010, 12:55 AM
Awesome.
Is there things that you cannot change when using the emulator because of it only using the 1 bank of inputs?
Yeah, there are a whole lot of things that you can't change....namely the "parameters" and a whole lot of "functions". Most everything in the "maps" section can be changed.
How does the emulator work, can you make changes "on the fly", or is it more like make a change, load file into emulator, and continue? Yes, you can make changes on the fly. There are times that you will get a "bump" or momentary loss of PCM (stumble or stall) depending on what you change and when you change it.
What does it take to change file to the 32K size?Hex editing software like HEX WORKSHOP. Then you simply select the 32768 bytes that you need (address E000 to 16000) and paste them into a new sheet, save it, and load it into the emulator definition.
Hope this helps.
