Old Tue, February 2nd, 2010, 05:33 PM
Part of the problem is that when you load the program into the pcm. Its loading in a different set of values. One of the values in edge's programming isn't jiving with the limits set in the pcm. Thus the code.
That why a lot of people are encouraging you to get a reflash of the pcm and when that happens you will get a different calibration code that the edge's programming might be more compatible with.
This is an issue that edge should address.
If the code isn't present when pcm is stock program then it is not your TB its more or less the calibration code and having compatibility issues with the edge.
Bill is going to have to look into this if edge can't help you.
Other brands of programmers have done this in the past also.
Usually the programming company is up on their stuff and can provide an update to fix the issue. A reflash might work also.
If you can put your HEX/calibration code in your user cp so Bill can see it.
