Old Tue, February 9th, 2010, 07:23 PM
Punisher's Avatar
Punisher Punisher is offline
Punisher is on a distinguished road
The piece is just held in by a couple of molded in clips. Just grab hold of the change piece and give it a good tug. May take a time or two. Much like the center console surround-trim that is around the radio/climate control. The first time you'd swear you're going to break something. After that it becomes easier each time. If you prefer, you can remove the surround-trim and reach inside around the back of the change holder and push it out from the backside. Again, either way it's just held in with molded plastic clips.
Before you try and beat the odds... make sure you can survive the odds beating you!
