Originally Posted by 88Racing
In the main menu on the programmer, select [Diagnostics] -> [Tech Support] -> [Version Info]. (You can ignore the warning message that will come up). The "Calibration Version" should look like "0.x.xxxx" where the last 4 x's are (usually) the same as the Serial Number. If the Version number DOES begin with zero ("0"), you have custom tuned files. If the Version begins with one ("1") though, so it looks like "1.x.xxxx", then the unit has canned tunes, not custom. Again - any calibration that looks like 0.x.xxxx is a CUSTOM build. All calibrations that begin with "1", i.e., 1.x.xxxx are CANNED calibrations.
You may also want to try and update pegasus then try to update the gryphon.
Thanks, I will check on that later.
Having problem updating pegasus though with my windows vista OS. Not showing any files to be updated when it goes through the process?
btw, I do have a call into PHP and Bill is hopefully going to be able to call me later today when he gets back in to help out with my questions. Hoping to order some custom tunes soon too.
