Old Thu, January 29th, 2009, 01:30 PM
Originally Posted by kokopellimotorsports View Post
Thanks for the info. I will check out your Album.
As far as the hot air, this probably could be an issue, but most cold air intakes set their filter right in the compartment. Though I do agree with the logic of colder denser air. With your write up I will probably do much the same as you.
Some of the pictures I've seen show the filter in a kind of "box" that looks like it's there to isolate the intake area somewhat from the engine heat. It's also possible that when moving, the whole thing is a moot point anyway due to the airflow through the engine compartment (as long as you keep the intake away from the flow through the radiator).
