Maybe
I put it back to Level 2 before I left work and I did not change the TS or GR this time. It's shifting fine now and the idle speed is a lot lower now. Here is what I "think" happenend. When I changed the TS & GR I didn't change anything else under the custom options menu. If it just loads "placeholder" settings for all the other options then maybe something else needs to be changed to compensate for the larger tire size and smaller gear ratio. Then again, this is all new to me so maybe I'm way off. Either way, Level 2 with no changes is working fine... Except for the spedo being off a bit.
