Old Fri, February 19th, 2010, 02:59 PM
Originally Posted by ballisticmike View Post
whats a good target temp when having an e-fan? i also have a gryphon programmer which shows me coolant temp. My coolant range right now is between about 190 to 205 when i'm on the highway, depending if i'm going uphill or downhill. i guess average is about 200 degrees maybe.
Should i make my efan power on sooner so that my max temp will be closer to 190-200 maybe? I have several temp settings on my DC Controls temp controller i can choose.. i think i set it at 194 which apparently is the thermostat range.
I personally think the coolant temperature should remain in the 200-210 range. The thermostat starts to open at 195, and will be fully open shortly thereafter. The stabilized temperature is controlled by your overall cooling system and the engine load. It SHOULD be above 200 to give you efficient engine operation. With a good pressure seal and 50-50 antifreeze, you won't boil below 250 degrees.
