Thread: quick question
Old Thu, February 25th, 2010, 11:13 AM
Originally Posted by Unleashedford View Post
THATS FREAKEN AWSOME!!! THANKS GUYS!!! and i had less then a 1/4 tank of 87 and i just filled it up with 91, is it okay if i run 93 even though it had a little 87 in it?
You probably can, but you may need to retard the spark some (I'd guess maybe 1.0 degrees) because you're probably burning a mix that's actually 90 octane. However, it probably won't matter much. If the knock sensors detect "ping", the spark will be automatically retarded - a lot, and that will prevent damage. But retarding the spark could actually give you better performance right now.
