Old Tue, March 9th, 2010, 09:25 PM
eabrust's Avatar
eabrust eabrust is offline
electro-mechanical geek
Originally Posted by NHRA6002 View Post
Well it got so bad and I haven't heard anything from Bill that I had to take the truck into the dealership and have the FICM reflashed by them. Now I have a truck that is ok in stock mode but can't use any other levels in my Evo as the truck will smoke and high EGT's even in level 1. Have talked to edge via email and tried new files from them but no success.
The exhaust note has also changed as it sounds like the variable vane is cycling unlike befor when I would start the truck it would at first sound open and throughty and then close off to a hiss. I wonder if Ford has a new program that is not compatable with the Evo?
Hey NHRA,
did you have your truck put back to stock before you took it in for reflash? Bummer about the tunes not working, but I would guess you need to update your EVO with the Edge fusion software to work with the latest Ford strategy (what is it now, VXCFH9?)
Bummer you sent in your PHP tuned FICM to get put back to stock, but it does prove a point somewhat that the PHP updated FICM has an issue (at least with triggering or keeping inductive heat flash going), where as stock program does not. I haven't been able to prove that out, as I have two FICMs I am swapping between (a stock and a modified), and all I have been able to prove is my bad actor PHP tuned FICM has 48 VDC (hence it seems it is program only, not dying due to power supply or solder joints, etc...)
I am still not running my PHP FICM (for same cold startup issue you had), but am getting closer to hopefully resolving my problem. First, I'm getting my EVO turned into a Gryphon, and following that, what I gather from Bill is that I will then have capability of reprogramming both the FICM and the ECM program via the Gryphon. Second, if I run a custom tune from Bill in the ECM, it will hopefully by default work with the updated FICM program better than the Ford program in the ECM.
I've also been steadily working through the whole 'stiction' issue with these injectors to try to resolve root cause of why it runs like crap cold. Last summer, I was running 15-40 dino oil, my truck would run great on stock FICM & ECM, but putting in the PHP FICM was bad on startup even on 90F days (truck needed warm up time in middle of Summer?...). Put in stock FICM, no problem.... Into winter, I was still running stock, but the truck would run rough for the frist 5+ minutes till EOT came up to ~160F, then it would go good. I got so sick of it needing so much warmup time, that I switched to 5-40 synthetic. That was an improvement, but it still took either some warmup in the driveway, or till engine got to ~120F till it smoothed out and ran good (still about 3-5 miles of driving).
As a side note about my whole injector/crappy startup issue and resolving root cause, about 200 miles ago, I drained 2 qts of the synthetic oil I'm running now (halfway into 5,000 miles service of this change), and added a product that claims to solve the injector stiction issue (I won't name it here yet, I don't want to advertise it, as I haven't had it in there long enough to claim anything as a matter of fact. However, if you do a search via google, you'll most likely find it discussed on most other forums out there, that's how I found it). The only thing I'll say about it is, currently, I hop in the truck, start it and go and it runs fairly well out of the gate with no warmup. I won't claim success until I can either put in the PHP FICM and it runs great cold (would mean injectors aren't sticking anymore even though inductive heat strategy isn't working), or untill truck continues to run great on stock programs after next oil change after this product has been dumped and replaced with all fresh oil. BTW, the product recommends leaving it in for a full 5000 mile change to fully do it's thing of removing oil deposits, etc, so it is definitely to early for me to endorse it at all, but it does seem promising given how my truck runs currently.
regards,
Eric
2006 F350 King Ranch
Gryphon & PHP tuned FICM
EGR deleted
4" Turboback
