Old Wed, March 10th, 2010, 02:59 PM
I dont think so because then it wouldn't be fair to the people who are waiting in line. As I said earlier, the safest thing to do would be loading the tow tune because it is designed to run a little richer than the performance tune. You can also go into the custom options menu and raise the WOT fuel a little bit if you feel that it is necissary. You wont need to go over 1.5 because then your just wasting gas. Bill will put it in the 1.3-1.4 range depending on elevation, but that is with the MAF sensor corrected for a different sized intake. Right now your sensor is reading that there is less air than there really is.
