Old Thu, April 1st, 2010, 11:11 AM
Running the A/C is usually what I use High Idle for. Also, if you sit for long periods (like napping at the rest stop... heh heh), you want to have the idle a bit higher so you don't get what's called "wet stacking", which is a buildup of unburnt deposits on the back of the exhaust valves.
I hope this helps.
